주요 콘텐츠로 건너뛰기
HP Chromebook 11 G8 EE Screen Replacement
필요한 것
  1. HP Chromebook 11 G8 EE Screen Replacement, Keyboard & Touchpad Assembly: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11 G8 EE Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Screen Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 11 G8 EE Screen Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 11 G8 EE Screen Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Screen Replacement, Bezel: 4 단계, 이미지 2개 중 1개 HP Chromebook 11 G8 EE Screen Replacement, Bezel: 4 단계, 이미지 2개 중 2개
    • Using your hands, pry off the hinge cover by lifting it.
  5. HP Chromebook 11 G8 EE Screen Replacement: 5 단계, 이미지 3개 중 1개 HP Chromebook 11 G8 EE Screen Replacement: 5 단계, 이미지 3개 중 2개 HP Chromebook 11 G8 EE Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Using the opening tool, pry the bezel away from the top case.
    • It requires a bit of force; you aren't going to break it!
  6. HP Chromebook 11 G8 EE Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the bezel toward you.
    • Peel it away from the screen gently.
  7. HP Chromebook 11 G8 EE Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Completely remove the bezel.
  8. HP Chromebook 11 G8 EE Screen Replacement, Screen: 8 단계, 이미지 1개 중 1개
    • Remove the four 3.5 mm screws with a Phillips #1 screwdriver.
  9. HP Chromebook 11 G8 EE Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the screen toward you.
  10. HP Chromebook 11 G8 EE Screen Replacement: 10 단계, 이미지 3개 중 1개 HP Chromebook 11 G8 EE Screen Replacement: 10 단계, 이미지 3개 중 2개 HP Chromebook 11 G8 EE Screen Replacement: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to peel away the black tape holding the connector.
  11. HP Chromebook 11 G8 EE Screen Replacement: 11 단계, 이미지 3개 중 1개 HP Chromebook 11 G8 EE Screen Replacement: 11 단계, 이미지 3개 중 2개 HP Chromebook 11 G8 EE Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Use the tweezers to pull away the tan tape.
    • You should see the colored wires of the connector.
  12. HP Chromebook 11 G8 EE Screen Replacement: 12 단계, 이미지 2개 중 1개 HP Chromebook 11 G8 EE Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Using the tweezers, lift up the small red latch on the connector.
    • Pull off the connector.
  13. HP Chromebook 11 G8 EE Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the screen.
결론
작성자
3다른 기여자 명과 함께
Isabella Brown
회원 가입일: 10/25/22
312 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G2
5 회원들
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 22
지난 30일: 93
전체 시간: 1,551
