주요 콘텐츠로 건너뛰기
소개
This guide will show you the correct way to remove the battery according to an HP Chromebook 11-2210nr in the need to replace a faulty or damaged battery. Once the battery is removed, access to speakers is more accessible.
  1. Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver. Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
    • Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. Using the metal spudger, remove the two bottom rubber pads located closer to the hinge of the laptop. Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver. The other two bottom rubber pads do not obtain any screws.
    • Using the metal spudger, remove the two bottom rubber pads located closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The other two bottom rubber pads do not obtain any screws.
  3. Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off. You will hear popping sounds when you are sliding the spudger along the device. For an easier removal, start from the sides and work your way in to the corners.
    • Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    지금 장보기
    iPhone X Fix Kits
    지금 장보기
  5. Carefully lift up the keyboard and gently place it towards you until the two ribbon wires become visible and place the keyboard down. Locate where the two ribbon wires are being held in place by two chips. This  does not disconnect the keyboard from the laptop just yet.
    • Carefully lift up the keyboard and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two chips.
    • This does not disconnect the keyboard from the laptop just yet.
  6. Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires. It is important to use the nylon spudger for the this step to avoid any metal on metal circuit damage. This step completely disconnects the keyboard to allow safe removal.
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is important to use the nylon spudger for the this step to avoid any metal on metal circuit damage.
    • This step completely disconnects the keyboard to allow safe removal.
  7. Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver. Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver.
    • Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver.
  8. Carefully unplug the bundle power cable by pulling both edges towards you. This successfully disconnects the battery from the laptop. This successfully disconnects the battery from the laptop.
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  9. Carefully lift the battery and safely remove it out of the laptop. The battery may have an adhesive sticker  attached to the bottom, if so apply more force when lifting up. The battery may have an adhesive sticker  attached to the bottom, if so apply more force when lifting up.
    • Carefully lift the battery and safely remove it out of the laptop.
    • The battery may have an adhesive sticker attached to the bottom, if so apply more force when lifting up.
결론
Kimberly Rodriguez
회원 가입일: 2018년 10월 02일
401 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Sam Houston State, Team S11-G3, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G3
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 98
