주요 콘텐츠로 건너뛰기
HP Chromebook 11-2210nr Keyboard Replacement
필요한 것
  1. HP Chromebook 11-2210nr Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 HP Chromebook 11-2210nr Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Keyboard Replacement: 2 단계, 이미지 1/3 HP Chromebook 11-2210nr Keyboard Replacement: 2 단계, 이미지 2/3 HP Chromebook 11-2210nr Keyboard Replacement: 2 단계, 이미지 3/3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr Keyboard Replacement: 3 단계, 이미지 1/3 HP Chromebook 11-2210nr Keyboard Replacement: 3 단계, 이미지 2/3 HP Chromebook 11-2210nr Keyboard Replacement: 3 단계, 이미지 3/3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr Keyboard Replacement: 4 단계, 이미지 1/3 HP Chromebook 11-2210nr Keyboard Replacement: 4 단계, 이미지 2/3 HP Chromebook 11-2210nr Keyboard Replacement: 4 단계, 이미지 3/3
    • Carefully lift off the keyboard and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two chips.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Keyboard Replacement: 5 단계, 이미지 1/3 HP Chromebook 11-2210nr Keyboard Replacement: 5 단계, 이미지 2/3 HP Chromebook 11-2210nr Keyboard Replacement: 5 단계, 이미지 3/3
    • Using the nylon spudger, lift the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is recommended to use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
결론
Bridget Rosales
회원 가입일: 10/02/18
121 평판
안내서 1개 작성함
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Sam Houston State, Team S11-G3, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 209
