주요 콘텐츠로 건너뛰기
HP Chromebook 11-2210nr SD Card Reader Replacement
필요한 것
  1. HP Chromebook 11-2210nr SD Card Reader Replacement, SD Card Reader: 1 단계, 이미지 1/2 HP Chromebook 11-2210nr SD Card Reader Replacement, SD Card Reader: 1 단계, 이미지 2/2
    • Turn over your laptop and remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr SD Card Reader Replacement: 2 단계, 이미지 1/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 2 단계, 이미지 2/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 2 단계, 이미지 3/3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr SD Card Reader Replacement: 3 단계, 이미지 1/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 3 단계, 이미지 2/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 3 단계, 이미지 3/3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr SD Card Reader Replacement: 4 단계, 이미지 1/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 4 단계, 이미지 2/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 4 단계, 이미지 3/3
    • Carefully lift off the keyboard and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two chips.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr SD Card Reader Replacement: 5 단계, 이미지 1/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 5 단계, 이미지 2/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 5 단계, 이미지 3/3
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • You must use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
  6. HP Chromebook 11-2210nr SD Card Reader Replacement: 6 단계, 이미지 1/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 6 단계, 이미지 2/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 6 단계, 이미지 3/3
    • Locate the SD card reader at the top left corner above the battery.
    • Flip up the plastic clasps holding the ZIF connectors into place by using the nylon spudger or your finger.
    • Gently slide out the ribbon cable, removing it from the SD Card Reader.
  7. HP Chromebook 11-2210nr SD Card Reader Replacement: 7 단계, 이미지 1/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 7 단계, 이미지 2/3 HP Chromebook 11-2210nr SD Card Reader Replacement: 7 단계, 이미지 3/3
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • This successfully disconnects the SD port from the laptop.
  8. HP Chromebook 11-2210nr SD Card Reader Replacement: 8 단계, 이미지 1/2 HP Chromebook 11-2210nr SD Card Reader Replacement: 8 단계, 이미지 2/2
    • Gently lift and remove SD Card Reader component from laptop.
결론
Gerardo Cardona
회원 가입일: 10/02/18
364 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Sam Houston State, Team S11-G3, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 170
