주요 콘텐츠로 건너뛰기
HP Chromebook 11-2210nr Speakers Replacement
필요한 것
  1. HP Chromebook 11-2210nr Speakers Replacement, Speakers: 1 단계, 이미지 1/2 HP Chromebook 11-2210nr Speakers Replacement, Speakers: 1 단계, 이미지 2/2
    • Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Speakers Replacement: 2 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 2 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 2 단계, 이미지 3/3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr Speakers Replacement: 3 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 3 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 3 단계, 이미지 3/3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr Speakers Replacement: 4 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 4 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 4 단계, 이미지 3/3
    • Carefully lift off the keyboard and gently place it towards you until the two ZIF ribbon wires become visible and place the keyboard down.
    • Locate where the two ZIF ribbon wires are connecting the keyboard to the motherboard in place by clasps.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Speakers Replacement: 5 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 5 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 5 단계, 이미지 3/3
    • Using the nylon spudger, lift the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is recommended to use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
  6. HP Chromebook 11-2210nr Speakers Replacement: 6 단계, 이미지 1/2 HP Chromebook 11-2210nr Speakers Replacement: 6 단계, 이미지 2/2
    • Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Speakers Replacement: 7 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 7 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 7 단계, 이미지 3/3
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Speakers Replacement: 8 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 8 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 8 단계, 이미지 3/3
    • Carefully lift the battery and safely remove it out of the laptop.
    • The battery may have an adhesive sticker attached to the bottom. If so, apply more force when lifting it up.
    • After the removal of the battery, the speakers will become accessible.
  9. HP Chromebook 11-2210nr Speakers Replacement: 9 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 9 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 9 단계, 이미지 3/3
    • Use the metal spudger to release the LEFT speakers from the laptop.
    • Use the metal spudger to release the RIGHT speaker from the laptop.
    • The two speakers are connected to a wire that runs along the bottom edge of the laptop and connected up to the motherboard.
  10. HP Chromebook 11-2210nr Speakers Replacement: 10 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 10 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 10 단계, 이미지 3/3
    • Unplug the speakers small wire bundle from the motherboard.
    • You will notice the speaker wire is pinched between a screw slot and underneath the motherboard.
  11. HP Chromebook 11-2210nr Speakers Replacement: 11 단계, 이미지 1/2 HP Chromebook 11-2210nr Speakers Replacement: 11 단계, 이미지 2/2
    • Remove the one 4mm screw located above the pinched wire.
  12. HP Chromebook 11-2210nr Speakers Replacement: 12 단계, 이미지 1/3 HP Chromebook 11-2210nr Speakers Replacement: 12 단계, 이미지 2/3 HP Chromebook 11-2210nr Speakers Replacement: 12 단계, 이미지 3/3
    • Using the nylon spudger, slightly pry up the motherboard to release the pinched wire.
    • This step completely disconnects the speaker from the laptop to be safely removed.
결론
Gerardo Cardona
회원 가입일: 10/02/18
364 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Sam Houston State, Team S11-G3, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 143
