소개
This guide will walk you through easy steps in order to change the keyboard for your HP Chromebook 11-v002dx.
You may want to try cleaning the area underneath your keys and keyboard before replacing your board entirely, as dust can occasionally accumulate and prevent the keyboard from functioning.
필요한 것
Place your laptop bottom up on your work space.
Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
다른 한 분이 해당 안내서를 완성하였습니다.
