주요 콘텐츠로 건너뛰기
HP Chromebook 11-v002dx Keyboard Replacement
필요한 것
  1. HP Chromebook 11-v002dx Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 HP Chromebook 11-v002dx Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Keyboard Replacement: 2 단계, 이미지 1/3 HP Chromebook 11-v002dx Keyboard Replacement: 2 단계, 이미지 2/3 HP Chromebook 11-v002dx Keyboard Replacement: 2 단계, 이미지 3/3
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Keyboard Replacement: 3 단계, 이미지 1/2 HP Chromebook 11-v002dx Keyboard Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Keyboard Replacement: 4 단계, 이미지 1/2 HP Chromebook 11-v002dx Keyboard Replacement: 4 단계, 이미지 2/2
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Heather Cooper
회원 가입일: 04/18/17
185 평판
안내서 1개 작성함
Cal Poly, Team S14-G1, Banghart Spring 2017 Cal Poly, Team S14-G1, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 675
