소개
This guide will walk you through easy steps in order to change the USB board for your HP Chromebook 11-v002dx.
You may want to try cleaning the area underneath your USB board, the inside of the USB port and audio jack, and the entire board before replacing your board entirely, as dust can occasionally accumulate and prevent the USB board from functioning.
필요한 것
Place your laptop bottom up on your work space.
Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
Pull out the black belt from across the battery.
Use your Phillips #0 screwdriver to unscrew the two .2 mm screws from the USB board.
Pull out the USB board from the laptop starting at its top right corner.
