소개
Sometimes the battery on the HP Chromebook 11-v011dx can malfunction and will need to be replaced. This guide will help you remove the battery.
필요한 것
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
거의 끝나갑니다!
결론
