주요 콘텐츠로 건너뛰기
HP Chromebook 11A G8 EE Bezel Replacement
필요한 것
  1. HP Chromebook 11A G8 EE Bezel Replacement, Keyboard Assembly: 1 단계, 이미지 1/2 HP Chromebook 11A G8 EE Bezel Replacement, Keyboard Assembly: 1 단계, 이미지 2/2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Bezel Replacement: 2 단계, 이미지 1/3 HP Chromebook 11A G8 EE Bezel Replacement: 2 단계, 이미지 2/3 HP Chromebook 11A G8 EE Bezel Replacement: 2 단계, 이미지 3/3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Bezel Replacement: 3 단계, 이미지 1/2 HP Chromebook 11A G8 EE Bezel Replacement: 3 단계, 이미지 2/2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Bezel Replacement, Bezel: 4 단계, 이미지 1/1
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Bezel Replacement: 5 단계, 이미지 1/1
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Bezel Replacement: 6 단계, 이미지 1/1
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Bezel Replacement: 7 단계, 이미지 1/1
    • You are finished once the bezel is off of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kim Travers
회원 가입일: 09/03/21
523 평판
안내서 2개 작성하였습니다
University of Alabama, Team 2-1, Bedsole Fall 2021 University of Alabama, Team 2-1, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S2G1
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Just curious why the back needs to be unscrewed and the keyboard removed to take off the bezel.
The spine piece can be removed with the device closed.
Also, the bezel is attached with a lot of adhesive. Be extremely careful to not break the bezel when removing it.
Scott - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 19
전체 시간: 483
