주요 콘텐츠로 건너뛰기
HP Chromebook 11A G8 EE Keyboard Assembly Replacement
필요한 것
  1. HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: 1 단계, 이미지 1/2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: 1 단계, 이미지 2/2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: 2 단계, 이미지 1/3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: 2 단계, 이미지 2/3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: 2 단계, 이미지 3/3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: 3 단계, 이미지 1/2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: 3 단계, 이미지 2/2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Ella Portwood
회원 가입일: 09/03/21
684 평판
안내서 4개 작성하였습니다
University of Alabama, Team 2-1, Bedsole Fall 2021 University of Alabama, Team 2-1, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S2G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 48
전체 시간: 2,440
