주요 콘텐츠로 건너뛰기
HP Chromebook 11A G8 EE Screen Replacement
필요한 것
  1. HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: 1 단계, 이미지 2개 중 1개 HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: 1 단계, 이미지 2개 중 2개
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Screen Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 11A G8 EE Screen Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 11A G8 EE Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11A G8 EE Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Screen Replacement, Bezel: 4 단계, 이미지 1개 중 1개
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Screen Replacement: 7 단계, 이미지 1개 중 1개
    • You are finished once the bezel is off of the device.
  8. HP Chromebook 11A G8 EE Screen Replacement, Screen: 8 단계, 이미지 1개 중 1개
    • Remove the four 3.5 mm screws with the Phillips #0 screwdriver.
  9. HP Chromebook 11A G8 EE Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the screen towards you.
  10. HP Chromebook 11A G8 EE Screen Replacement: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Once the screen is flipped down, use the tweezers to peel away the black tape holding down the connector.
  11. HP Chromebook 11A G8 EE Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Next, peel away the tan tape, using the tweezers, exposing the screen connector.
  12. HP Chromebook 11A G8 EE Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Using the tweezers, remove the connector by the latch attached to it.
  13. HP Chromebook 11A G8 EE Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Finally, pull away the screen, to remove it from the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kim Travers
회원 가입일: 09/03/21
553 평판
안내서 2개를 작성함
1가이드 댓글
Does IFixit Sell this screen? I am unable to source parts and this screen for these educational units by HP. I wish iFixit would also list the parts that are needed for the repairs and not just the tools they sell.
Glenn Silva - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 82
전체 시간: 4,483
