주요 콘텐츠로 건너뛰기
HP Chromebook 11a-nb0013dx Battery Replacement
필요한 것
  1. HP Chromebook 11a-nb0013dx Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Position your closed computer on a flat surface, with the back facing up.
    • Remove all eight 8 mm Philips #0 screws from the bottom cover.
  2. HP Chromebook 11a-nb0013dx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 4 rubber feet with a nylon spudger or an opening tool.
  3. HP Chromebook 11a-nb0013dx Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Flip over your computer and open it.
    • Using a plastic pick, level up the edges of the keyboard by sliding the pick along the gap.
    • Apply downward pressure to separate the bottom of the Chromebook and the keyboard.
    • Do the same for all 4 sides of the keyboard until it starts to lift.
    • You should hear popping sounds as you slide the plastic pick along the edge.
  4. HP Chromebook 11a-nb0013dx Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift up the keyboard from the bottom.
  5. HP Chromebook 11a-nb0013dx Battery Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Identify the zero insertion force (ZIF) connector.
    • Now, disconnect the cable by using the tip of the iFixit opening tool or your fingernail to flip up the small locking flap.
    • You can now gently pull out the cable.
    • No force is needed to plug in or remove the cable.
  6. HP Chromebook 11a-nb0013dx Battery Replacement: 6 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Identify the second cable and the ZIF connector attatching the cable to the motherboard. Then, unclip it with the iFixit opening tool.
    • To do this, use the iFixit opening tool to flip up the small locking flap located on the ZIF connector.
    • Proceed by gently pulling the cable straight out of the connector to disconnect the cable.
    • Be careful, the cord is very fragile!
  7. HP Chromebook 11a-nb0013dx Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Once the white cord is removed, this is what it should look like. At this point, you should be able to completely take off the keyboard.
  8. HP Chromebook 11a-nb0013dx Battery Replacement: 8 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Lift up the adhesive holding the battery connector.
    • Then, pull the battery connector straight towards you.
    • It is important to pull of the battery connector straight towards you to avoid breaking the vord.
  9. HP Chromebook 11a-nb0013dx Battery Replacement: 9 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the four 4 mm Philips #00 screws.
  10. HP Chromebook 11a-nb0013dx Battery Replacement: 10 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift the battery by holding the top.
결론
작성자
3다른 기여자 명과 함께
Nafisat Ibrahim
회원 가입일: 02/09/23
349 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 327
