주요 콘텐츠로 건너뛰기
HP Chromebook 11a-nb0013dx Motherboard Replacement
필요한 것
  1. HP Chromebook 11a-nb0013dx Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Position the Chromebook with the bottom facing up.
    • Locate the 8 screws on the back of the Chromebook.
    • Next, remove the 8 (8mm) screws using the phillips screw driver with the #0 bit.
  2. HP Chromebook 11a-nb0013dx Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the 4 rubber feet on the bottom of the laptop.
    • Pry them off with the metal spudger or an iFixit opening pick.
  3. HP Chromebook 11a-nb0013dx Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Flip over and open the Chromebook.
    • Locate the seem surrounding the keyboard and track pad.
    • Use an iFixit opening pick to pry the keyboard from the laptop
  4. HP Chromebook 11a-nb0013dx Motherboard Replacement: 4 단계, 이미지 3개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 4 단계, 이미지 3개 중 2개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Gentally lift up the keyboard and locate the two ribbons attatched to the motherboard.
    • Use the IFixit Opening Tool to lift the two tabs located on the zero insertion force (ZIF) connectors.
    • To do this, use the tip of the IFixit Opening Tool to flip up the small locking flap and gently pull the ribbon out.
    • Then, fully remove the keyboard and set aside.
  5. HP Chromebook 11a-nb0013dx Motherboard Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the bundled cable connector connecting the battery to the motherboard.
    • Use the precision tweezers to peel back the black tape covering the bundled cable connector.
    • Next, use the precision tweezers to grab the edge of the connector and slowly pull the cable towards you.
  6. HP Chromebook 11a-nb0013dx Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the bundled cable connector connecting the speakers to the motherboard.
    • Using the precision tweezers, peel back the plastic that is covering the bundled cable connector.
    • Then, use the precision tweezers to grab the edges of the bundled cable connector and remove by pulling towards the battery.
  7. HP Chromebook 11a-nb0013dx Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the LDC cable connecting the screen to the motherboard.
    • Using the precision tweezers, peel back the plastic covering the LDC cable connector.
    • Then, use the precision tweezers to gently pull back the LDC cable towards the screen.
  8. HP Chromebook 11a-nb0013dx Motherboard Replacement: 8 단계, 이미지 3개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 8 단계, 이미지 3개 중 2개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Locate the ribbons and their ZIF connectors connecting the motherboard and the daughterboard.
    • Use the precision tweezers to peel back the plastic and uncover the ZIF connectors located at the end of each ribbon.
    • Use the IFixit Opening Tool to flip up the locking flap holding the ribons in place.
    • Then, gently pull out each ribon.
    • On the top left corner of the motherboard, gently unplug the bundled cable from the motherboard.
  9. HP Chromebook 11a-nb0013dx Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Locate the 6 screws holding the motherboard in place.
    • Using the philips screw driver with the #0 bit, unscrew the 6 (4mm) screws and set them aside.
    • After all the screws are removed, remove the USB-C bracket in the top right hand corner and set aside.
  10. HP Chromebook 11a-nb0013dx Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Chromebook 11a-nb0013dx Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Once the motherboard is not connected to any other components of the Chromebook, gentely remove.
    • When removing the motherboard, lift up and to the left.
결론
작성자
3다른 기여자 명과 함께
Ava Corona
회원 가입일: 02/09/23
281 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 492
