소개
Use this guide to replace a faulty battery in your HP Chromebook 14 G3.
The battery is the power source of your Chromebook. A faulty battery can cause your Chromebook to power down irregularly and cause your Chromebook to age faster. If these issues persist then it may cause the Chromebook to not function.
Make sure to troubleshoot your issue before following the guide as replacing the battery may not be the solution.
Power tools are not recommended for this type of repair because an excessive amount of force can break the computer's parts.
필요한 것
