주요 콘텐츠로 건너뛰기
HP Chromebook 14 G4 Keyboard Assembly Replacement
필요한 것
  1. HP Chromebook 14 G4 Keyboard Assembly Replacement, Keyboard Assembly: 1 단계, 이미지 2개 중 1개 HP Chromebook 14 G4 Keyboard Assembly Replacement, Keyboard Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the thirteen 2.5 mm Phillips #0 screws on the underside of the laptop that secure the keyboard assembly.
    • Flip the laptop over and open the lid.
    • Insert a nylon spudger in the gap between the keyboard assembly and lower case.
    • Gently pry around the entire perimeter until the keyboard assembly fully releases.
  2. HP Chromebook 14 G4 Keyboard Assembly Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14 G4 Keyboard Assembly Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14 G4 Keyboard Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Slightly lift the keyboard assembly with care not to strain the attached ribbon cables.
    • Flip up the two black ZIF locking flaps that secure the keyboard and touchpad ribbon cables to their motherboard sockets.
    • Gently pull the keyboard and touchpad ribbon cables out of their motherboard sockets.
  3. HP Chromebook 14 G4 Keyboard Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the keyboard assembly off of the chassis.
결론
작성자
1다른 기여자 명과 함께
Christian Leaman
회원 가입일: 09/05/24
551 평판
안내서 3개를 작성함
Gateway, Team 8-3, Gonzalez Fall 2024 Gateway, Team 8-3, Gonzalez Fall 2024 회원
GCC-GONZALEZ-F24S8G3
5 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 39
