주요 콘텐츠로 건너뛰기
HP Chromebook 14 G5 SD card reader Replacement
필요한 것
  1. HP Chromebook 14 G5 SD card reader Replacement, SD card reader: 1 단계, 이미지 1/1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 SD card reader Replacement: 2 단계, 이미지 1/1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 SD card reader Replacement: 3 단계, 이미지 1/1
    • Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
  4. HP Chromebook 14 G5 SD card reader Replacement: 4 단계, 이미지 1/1
    • Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
  5. HP Chromebook 14 G5 SD card reader Replacement: 5 단계, 이미지 1/2 HP Chromebook 14 G5 SD card reader Replacement: 5 단계, 이미지 2/2
    • Disconnect the Flexible Flat Cable (FFC) from the motherboard.
  6. HP Chromebook 14 G5 SD card reader Replacement: 6 단계, 이미지 1/1
    • Remove the SD card reader the device.
결론
Yuqi Wang
회원 가입일: 10/01/19
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 12
전체 시간: 298
