주요 콘텐츠로 건너뛰기
HP Chromebook 14 G5 Wi-Fi Card Replacement
필요한 것
  1. HP Chromebook 14 G5 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2개 중 2개
    • Use a spudger to remove four rubber feet from the corners of the laptop.
    • Use a spudger to remove seven silicone covers.
  2. HP Chromebook 14 G5 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 11 screws from the bottom panel using a Phillips #1 screwdriver.
  3. HP Chromebook 14 G5 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the laptop over and open up the display.
    • Using a opening pick, carefully separate the top housing from the bottom housing by working your way around the perimeter of the laptop and prying it open.
  4. HP Chromebook 14 G5 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Peel back the black tape covering the battery connector.
    • Using the spudger, unplug the battery connector from the motherboard.
  5. HP Chromebook 14 G5 Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the keyboard ribbon lock with the spudger and disconnect the keyboard ribbon cable from the motherboard.
  6. HP Chromebook 14 G5 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift the touch pad ribbon lock with the spudger and disconnect the touch pad ribbon cable from the motherboard.
    • Remove the keyboard assembly from the device housing.
  7. HP Chromebook 14 G5 Wi-Fi Card Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 7 단계, 이미지 2개 중 2개
    • Using the spudger, disconnect the two antennas from the Wi-Fi card.
  8. HP Chromebook 14 G5 Wi-Fi Card Replacement: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card.
  9. HP Chromebook 14 G5 Wi-Fi Card Replacement: 9 단계, 이미지 2개 중 1개 HP Chromebook 14 G5 Wi-Fi Card Replacement: 9 단계, 이미지 2개 중 2개
    • Gently remove the Wi-Fi card.
결론
작성자
2다른 기여자 명과 함께
Ethan Tran
회원 가입일: 10/24/23
169 평판
안내서 1개를 작성함
CSU Los Angeles, Team 13-1, Ribeiro Fall 2023 CSU Los Angeles, Team 13-1, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S13G1
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 359
