주요 콘텐츠로 건너뛰기
소개
Easy and quick replacement of the Chromebook screen.
부품
지정된 부품이 없습니다.
  1. We will be replacing the screen on this HP Chromebook. ***Unfortunately I did get a shot of the sweet crack on this screen. We will start by removing this screws on the bottom left and right of the screen, just above the escape key and power button.
    • We will be replacing the screen on this HP Chromebook. ***Unfortunately I did get a shot of the sweet crack on this screen.
    • We will start by removing this screws on the bottom left and right of the screen, just above the escape key and power button.
  2. Next will start to remove the front "bezel" with a simple spudger. It is best to start from the bottom (now we here) of the screen.   *couldn't resist The bottom will have adhesive/double sided tape that may or may not give you trouble. It is not enough to prevent you from removing the screen, just be aware as it is near the screen circuit board.
    • Next will start to remove the front "bezel" with a simple spudger. It is best to start from the bottom (now we here) of the screen. *couldn't resist
    • The bottom will have adhesive/double sided tape that may or may not give you trouble. It is not enough to prevent you from removing the screen, just be aware as it is near the screen circuit board.
  3. Once removed, we can proceed to remove (4) screws that hold the screen to the laptop case. Marked in blue are the locations for the screws. Screws are closest to screen and on a light silver bracket. Pull screen forward and lay down on keyboard.
    • Once removed, we can proceed to remove (4) screws that hold the screen to the laptop case.
    • Marked in blue are the locations for the screws. Screws are closest to screen and on a light silver bracket. Pull screen forward and lay down on keyboard.
  4. The ribbon cable is connected at the bottom of the screen. Tape is placed over the connection and it is easily peeled and easy to reuse. I would not advise cutting the tape. Connect your new screen and go backwards through the steps to install. Connect your new screen and go backwards through the steps to install.
    • The ribbon cable is connected at the bottom of the screen. Tape is placed over the connection and it is easily peeled and easy to reuse. I would not advise cutting the tape.
    • Connect your new screen and go backwards through the steps to install.
  5. When re-installed and laptop is closed, check the back hinge area as it does not easily snap back in together. Pat yourself on the back if you can get it all together perfectly!
    • When re-installed and laptop is closed, check the back hinge area as it does not easily snap back in together. Pat yourself on the back if you can get it all together perfectly!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ricky
회원 가입일: 2013년 09월 17일
813 평판
안내서 3개 작성하였습니다
TechTucson WeFixThat TechTucson WeFixThat 회원
Community
2 회원들
안내서 4개 작성하였습니다
댓글 2개
Great walkthrough but missed one of the screws in the first step. There's one on the right and left. Nothing a little superglue couldn't fix.
ronguyor - 답글
That ribbon connector sure is finicky, It's really hard to actually pop it back in without putting too much force to it and bending it up. (for me atleast)
Bo-John Woltman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 38
30일 전: 133
전체 시간: 8,190
