주요 콘텐츠로 건너뛰기
HP Chromebook 14-Q070NR Keyboard Replacement
필요한 것
  1. HP Chromebook 14-Q070NR Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Keyboard Replacement: 2 단계, 이미지 1/3 HP Chromebook 14-Q070NR Keyboard Replacement: 2 단계, 이미지 2/3 HP Chromebook 14-Q070NR Keyboard Replacement: 2 단계, 이미지 3/3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Keyboard Replacement: 3 단계, 이미지 1/3 HP Chromebook 14-Q070NR Keyboard Replacement: 3 단계, 이미지 2/3 HP Chromebook 14-Q070NR Keyboard Replacement: 3 단계, 이미지 3/3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Keyboard Replacement: 4 단계, 이미지 1/3 HP Chromebook 14-Q070NR Keyboard Replacement: 4 단계, 이미지 2/3 HP Chromebook 14-Q070NR Keyboard Replacement: 4 단계, 이미지 3/3
    • Once the ribbons are detached, remove the keyboard from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexandra Bagarra
회원 가입일: 10/02/17
122 평판
안내서 1개 작성함
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G5
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 297
