주요 콘텐츠로 건너뛰기
HP Chromebook 14-Q070NR Keyboard Replacement
필요한 것
  1. HP Chromebook 14-Q070NR Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Once the ribbons are detached, remove the keyboard from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexandra Bagarra
회원 가입일: 10/02/17
122 평판
안내서 1개를 작성함
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G5
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 386
