주요 콘텐츠로 건너뛰기
HP Chromebook 14-Q070NR Motherboard Replacement
필요한 것
  1. HP Chromebook 14-Q070NR Motherboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Motherboard Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Motherboard Replacement: 4 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 4 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Motherboard Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Motherboard Replacement: 6 단계, 이미지 2개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully lift the battery and remove it from the device.
  8. HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 2개 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 3개
    • Carefully remove the (3) three plastic strips attached to the motherboard.
  9. HP Chromebook 14-Q070NR Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the (5) five screws.
  10. HP Chromebook 14-Q070NR Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
  11. HP Chromebook 14-Q070NR Motherboard Replacement: 11 단계, 이미지 2개 중 1개 HP Chromebook 14-Q070NR Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern.
    • Be very careful not to detach the motherboard to quickly or forcefully since you could damage or break it.
결론
작성자
3다른 기여자 명과 함께
Jose Hernandez
회원 가입일: 10/02/17
101 평판
안내서 1개를 작성함
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G5
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 389
