이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will focus on the removal of the WiFi card by first removing the back panel from the device and getting to the card accordingly. If your laptop fails to detect wireless connections, then you might need to replace your WiFi card.
필요한 것
Turn the Chromebook upside down, as shown in the first image.
Remove the five rubber feet pieces as shown using a spudger.
Proceed to remove all exposed 4.2 mm Phillips #1 screws on the bottom of the Chromebook.
다른 한 분이 해당 안내서를 완성하였습니다.
