주요 콘텐츠로 건너뛰기
HP Chromebook 14-ak013dx Charging Port Replacement
필요한 것
  1. HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Position the laptop so that the bottom is facing towards you and the fold facing away.
    • Using a plastic opening tool or another prying device, remove the five rubber stoppers on the upper side of the laptop to reveal screws.
    • Using a Phillips-head screwdriver or another capable tool, unscrew the thirteen 5.0 mm Phillips #1 screws on the base of the laptop.
  2. HP Chromebook 14-ak013dx Charging Port Replacement: 2 단계, 이미지 1/2 HP Chromebook 14-ak013dx Charging Port Replacement: 2 단계, 이미지 2/2
    • Flip the laptop over and open it so the keyboard is visible.
    • Using a plastic opening or prying tool, insert the tool between the keyboard and bottom casing. Then rotate the tool away from the laptop to open it up.
    • Be sure not to pull the keyboard away just yet as the ribbons are still connected.
  3. HP Chromebook 14-ak013dx Charging Port Replacement: 3 단계, 이미지 1/3 HP Chromebook 14-ak013dx Charging Port Replacement: 3 단계, 이미지 2/3 HP Chromebook 14-ak013dx Charging Port Replacement: 3 단계, 이미지 3/3
    • Using a plastic opening tool or your fingers, lift the two black flaps that hold the ribbons connecting the keyboard and touch-pad to fully disconnect the keyboard from the laptop.
    • Disconnect the battery cable from the system board
  4. HP Chromebook 14-ak013dx Charging Port Replacement: 5 단계, 이미지 1/3 HP Chromebook 14-ak013dx Charging Port Replacement: 5 단계, 이미지 2/3 HP Chromebook 14-ak013dx Charging Port Replacement: 5 단계, 이미지 3/3
    • Partially remove the tape that is covering the two wires connecting to the wireless adaptor.
    • Disconnect the white and black wires from the adaptor and remove it from the plastic piece used to guide the wire to free up space.
    • The wires are labeled (1) and (2), make note of their position for reassembly
  5. HP Chromebook 14-ak013dx Charging Port Replacement: 6 단계, 이미지 1/3 HP Chromebook 14-ak013dx Charging Port Replacement: 6 단계, 이미지 2/3 HP Chromebook 14-ak013dx Charging Port Replacement: 6 단계, 이미지 3/3
    • Using a prying tool or your fingers, remove the charging port head.
    • Pull by the white plastic or by the wiring away from the connector to remove the piece completely.
    • Replace the broken charging port with a new one.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Igli Duro
회원 가입일: 02/15/17
200 평판
안내서 1개 작성함
USF Tampa, Team 10-2, Remmell Spring 2017 USF Tampa, Team 10-2, Remmell Spring 2017 회원
USFT-REMMELL-S17S10G2
4 회원들
안내서 1개 작성하였습니다
댓글 2개
Where can you find a replacement charger port? My model is HP chromebook 11 g5ee
Neah McGovern - 답글
Worked! THANK YOU!
RACHEL LICATA - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 23
전체 시간: 5,741
