주요 콘텐츠로 건너뛰기
HP Chromebook 14-ak013dx Keyboard Replacement
필요한 것
  1. HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: 1 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: 1 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: 1 단계, 이미지 3개 중 3개
    • Using a p01 screwdriver bit, unscrew the 13 screws on the back of the laptop (two will be under the rubber footpads)
    • Flip to laptop over and raise the screen. You will need to use a tool to "pop" the keyboard off, slowly sliding the tool along the outside
  2. HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: 2 단계, 이미지 3개 중 3개
    • Carefully raise the keyboard off the body of the laptop
    • Locate two ribbons connecting the keyboard to the motherboard
    • Gently flip up the bars holding the ribbons in place, and remove the ribbon
  3. HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: 3 단계, 이미지 3개 중 3개
    • Separate the keyboard from the body of the laptop
    • Using a p001 screwdriver, remove the two screws holding the touchpad in place
    • Gently lift the bar holding the ribbon in place, and remove the ribbon
  4. HP Chromebook 14-ak013dx Keyboard Replacement, Separate the Keyboard and Touchpad: 4 단계, 이미지 2개 중 1개 HP Chromebook 14-ak013dx Keyboard Replacement, Separate the Keyboard and Touchpad: 4 단계, 이미지 2개 중 2개
    • Carefully push on the 'knob' on the touchpad; the touchpad will fall out of the keyboard
    • Carefully store the touchpad separately from the keyboard if not immediately replacing the keyboard
결론
To reassemble your device, follow these instructions in reverse order. Add the old touchpad to the new keyboard, and be careful reattaching all ribbons. Keyboard should 'snap' into place before put screws back on the body.
작성자
1다른 기여자 명과 함께
Cameron C Blanchard
회원 가입일: 09/16/20
524 평판
안내서 4개를 작성함
dwsad dwsad 회원
Community
1 회원
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 194
