주요 콘텐츠로 건너뛰기
HP Chromebook 14-ak013dx Touchpad Replacement
필요한 것
  1. HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 1 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 1 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 1 단계, 이미지 3개 중 3개
    • With the laptop upside down, remove the 13 screws with a P0 screwdriver (2 screws are located under the rubber footpads)
    • Open the screen, accessing the keyboard; gently pry the keyboard off the body careful not to pull out the ribbons
  2. HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 2 단계, 이미지 3개 중 3개
    • Gently lift up the keyboard from the main body, careful not to pull out the ribbons
    • The black bars holding the ribbons in place will flip up with light pressure, releasing the ribbons
  3. HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 3 단계, 이미지 3개 중 3개
    • Separate the keyboard from the main body of the laptop
    • Using a P00 Screwdriver, remove the two screws holding the touchpad in place
    • Use light pressure to flip up the black bar holding the ribbon in place
  4. HP Chromebook 14-ak013dx Touchpad Replacement, Removing the Touchpad: 4 단계, 이미지 2개 중 1개 HP Chromebook 14-ak013dx Touchpad Replacement, Removing the Touchpad: 4 단계, 이미지 2개 중 2개
    • Use a tool to push down on the knob highlighted, the touchpad will fall out of the front of the keyboard
    • If not immediately replacing the touchpad, safely secure the old keyboard
결론
To reassemble your device, follow these instructions in reverse order. Ribbon guards should fall back into place securely. Keyboard should 'snap' back into place before the 13 screws.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Cameron C Blanchard
회원 가입일: 09/16/20
524 평판
안내서 4개를 작성함
dwsad dwsad 회원
Community
1 회원
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 212
