주요 콘텐츠로 건너뛰기
HP Chromebook 14-ak013dx USB Port Replacement
필요한 것
  1. HP Chromebook 14-ak013dx USB Port Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx USB Port Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn the Chromebook upside down, as shown in the first image.
    • Remove the five rubber feet pieces as shown using a metal spudger.
  2. HP Chromebook 14-ak013dx USB Port Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx USB Port Replacement: 2 단계, 이미지 3개 중 3개
    • Begin removal of the back panel by unscrewing all exposed screws using a small Phillips screwdriver.
    • Use a plastic prying tool to split the back panel from the keyboard.
    • Move the prying tool around the sides of the back panel to detach it. Do not fully remove the panel, taking note of the two ribbon cables.
  3. HP Chromebook 14-ak013dx USB Port Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx USB Port Replacement: 3 단계, 이미지 3개 중 3개
    • Remove both ribbon cables attaching the separated keyboard to the motherboard.
    • The large black ribbon cable was a tab that should be pried open to loosen the ribbon from its hub. Use the plastic opening tool as shown.
    • Gently pull out the short white ribbon cable out of its hub.
  4. HP Chromebook 14-ak013dx USB Port Replacement: 4 단계, 이미지 2개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement: 4 단계, 이미지 2개 중 2개
    • Peel up the adhered ribbon cable. This cable does not need to be detached from the motherboard.
    • Use a plastic opening tool to disconnect the battery before going any further by inserting the tool between the plug and the hub where the recesses are on either side of the plug.
  5. HP Chromebook 14-ak013dx USB Port Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the four M2xL3 screws , shown in the picture, using a Phillips screwdriver.
    • Carefully lift the battery out of its place, avoiding the previously adhered silver ribbon cable in the process.
  6. HP Chromebook 14-ak013dx USB Port Replacement, USB Port: 6 단계, 이미지 2개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement, USB Port: 6 단계, 이미지 2개 중 2개
    • Lift the retaining bar on the USB port board with an opening tool.
  7. HP Chromebook 14-ak013dx USB Port Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the ribbon cable from its connector on the USB port board.
  8. HP Chromebook 14-ak013dx USB Port Replacement: 8 단계, 이미지 3개 중 1개 HP Chromebook 14-ak013dx USB Port Replacement: 8 단계, 이미지 3개 중 2개 HP Chromebook 14-ak013dx USB Port Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the two 1.5 mm screws from the USB board using a Phillips #0 screwdriver.
  9. HP Chromebook 14-ak013dx USB Port Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully lift the USB ports out of the computer.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 466
