주요 콘텐츠로 건너뛰기
HP Chromebook 14-ak041dx Wireless Card Replacement
필요한 것
  1. HP Chromebook 14-ak041dx Wireless Card Replacement, Keyboard: 1 단계, 이미지 1/2 HP Chromebook 14-ak041dx Wireless Card Replacement, Keyboard: 1 단계, 이미지 2/2
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Wireless Card Replacement: 2 단계, 이미지 1/3 HP Chromebook 14-ak041dx Wireless Card Replacement: 2 단계, 이미지 2/3 HP Chromebook 14-ak041dx Wireless Card Replacement: 2 단계, 이미지 3/3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Wireless Card Replacement: 3 단계, 이미지 1/3 HP Chromebook 14-ak041dx Wireless Card Replacement: 3 단계, 이미지 2/3 HP Chromebook 14-ak041dx Wireless Card Replacement: 3 단계, 이미지 3/3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx Wireless Card Replacement, Battery: 4 단계, 이미지 1/2 HP Chromebook 14-ak041dx Wireless Card Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx Wireless Card Replacement: 5 단계, 이미지 1/3 HP Chromebook 14-ak041dx Wireless Card Replacement: 5 단계, 이미지 2/3 HP Chromebook 14-ak041dx Wireless Card Replacement: 5 단계, 이미지 3/3
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx Wireless Card Replacement: 6 단계, 이미지 1/1
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx Wireless Card Replacement, Heat Sink: 7 단계, 이미지 1/3 HP Chromebook 14-ak041dx Wireless Card Replacement, Heat Sink: 7 단계, 이미지 2/3 HP Chromebook 14-ak041dx Wireless Card Replacement, Heat Sink: 7 단계, 이미지 3/3
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
  8. HP Chromebook 14-ak041dx Wireless Card Replacement, Wireless Card: 8 단계, 이미지 1/2 HP Chromebook 14-ak041dx Wireless Card Replacement, Wireless Card: 8 단계, 이미지 2/2
    • Remove the single 2.5mm Phillips #00 screw from the wireless card.
    • Gently pull the wireless card from the motherboard to remove it.
결론
Kristen Gismondi
회원 가입일: 11/12/14
82,023 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,198개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 158
