주요 콘텐츠로 건너뛰기
HP Chromebook 14-ca061dx Display Replacement
필요한 것
  1. HP Chromebook 14-ca061dx Display Replacement, Display: 1 단계, 이미지 3개 중 1개 HP Chromebook 14-ca061dx Display Replacement, Display: 1 단계, 이미지 3개 중 2개 HP Chromebook 14-ca061dx Display Replacement, Display: 1 단계, 이미지 3개 중 3개
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: 3 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
    Do not use a metal tool there is critical circuitry underneath.
    PC Sales - 답글
    Do not penetrate more than 2-3mm and stay flat to the screen and you will be okay. It takes skill and precision. A plastic card would work as well.
    Steven Franchitti -
    Use a flat tool and a little bit of alcohol to assist in undoing the adhesive, otherwise there may be damage to the bezel.
    Steven Franchitti - 답글
  4. HP Chromebook 14-ca061dx Display Replacement: 4 단계, 이미지 2개 중 1개 HP Chromebook 14-ca061dx Display Replacement: 4 단계, 이미지 2개 중 2개
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 14-ca061dx Display Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: 6 단계, 이미지 2개 중 1개 HP Chromebook 14-ca061dx Display Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the LCD/display panel from the Chromebook frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jean Arevalo
회원 가입일: 10/31/19
778 평판
안내서 6개를 작성함
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 UMass Dartmouth, Team S2-G5, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G5
3 회원들
안내서 6개를 작성함
댓글 한 개
should disconnect the laptop battery first
TJ Kleckner - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 28
전체 시간: 2,821
