소개
This guide contains step-by-step instructions for replacing the keyboard and surrounding area on an HP Chromebook 14-ca061dx. Before repairing any internal piece, you must first remove the keyboard.
To complete this guide, you will need the opening tool, the Phillips 64-bit screwdriver with the PH0 head, and a spudger.
Whether your trackpad is malfunctioning or you need to repair an internal component, following these directions will help you complete the replacement process safely and effectively!
필요한 것
이 단계에 사용된 도구:Tweezers$3.99
Flip the Chromebook to the underside with the hinge at the top.
Remove the seven, small rubber stoppers using angled tweezers.
댓글 한 개
good afternoon, excuse me, I have a question, I also have the same brand HP Chromebook 14-ca061dx and I just want to know where the anti-write screw is, I want to remove the anti-write screw to install windows 10..
