주요 콘텐츠로 건너뛰기
HP Chromebook 14-ca061dx Speaker Replacement
필요한 것
  1. HP Chromebook 14-ca061dx Speaker Replacement, Keyboard: 1 단계, 이미지 1/3 HP Chromebook 14-ca061dx Speaker Replacement, Keyboard: 1 단계, 이미지 2/3 HP Chromebook 14-ca061dx Speaker Replacement, Keyboard: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $3.99
    구매
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Speaker Replacement: 2 단계, 이미지 1/3 HP Chromebook 14-ca061dx Speaker Replacement: 2 단계, 이미지 2/3 HP Chromebook 14-ca061dx Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Speaker Replacement: 3 단계, 이미지 1/2 HP Chromebook 14-ca061dx Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Speaker Replacement: 4 단계, 이미지 1/2 HP Chromebook 14-ca061dx Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Speaker Replacement: 5 단계, 이미지 1/3 HP Chromebook 14-ca061dx Speaker Replacement: 5 단계, 이미지 2/3 HP Chromebook 14-ca061dx Speaker Replacement: 5 단계, 이미지 3/3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Speaker Replacement: 6 단계, 이미지 1/3 HP Chromebook 14-ca061dx Speaker Replacement: 6 단계, 이미지 2/3 HP Chromebook 14-ca061dx Speaker Replacement: 6 단계, 이미지 3/3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Speaker Replacement: 7 단계, 이미지 1/3 HP Chromebook 14-ca061dx Speaker Replacement: 7 단계, 이미지 2/3 HP Chromebook 14-ca061dx Speaker Replacement: 7 단계, 이미지 3/3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Speaker Replacement: 8 단계, 이미지 1/1
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Speaker Replacement, Speaker: 9 단계, 이미지 1/2 HP Chromebook 14-ca061dx Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Remove the JIS #000 screws that connect the speaker piece to the base of the laptop.
    • When all screws are unfastened, be cautious when moving the speaker piece. There are a couple cables attached from the speaker to the motherboard. We will detach these wires in the next steps.
  10. HP Chromebook 14-ca061dx Speaker Replacement: 10 단계, 이미지 1/2 HP Chromebook 14-ca061dx Speaker Replacement: 10 단계, 이미지 2/2
    • You will see the speaker cables (red, black, and white cables) connected to the motherboard.
    • Carefully, peel off the tape covering the red, white, and black cables connecting the speaker to the motherboard.
    • Remove cables from the motherboard.
    • Pull cables from the tip, and not from the wires. These wires could easily snap and break.
  11. HP Chromebook 14-ca061dx Speaker Replacement: 11 단계, 이미지 1/1
    • Remove speaker piece from the base of the laptop.
결론
Jean Arevalo
회원 가입일: 10/31/19
778 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 UMass Dartmouth, Team S2-G5, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 214
