주요 콘텐츠로 건너뛰기
HP Chromebook 14-x010wm Motherboard Replacement
필요한 것
  1. HP Chromebook 14-x010wm Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 HP Chromebook 14-x010wm Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Start with unscrewing all 16 5.7mm screws from the bottom of the laptop.
    • Make sure to remove the rubber pads covering 4 of the screws near the back of the laptop.
  2. HP Chromebook 14-x010wm Motherboard Replacement: 2 단계, 이미지 1/1
    • Pop the clips around the perimeter of the keyboard tray.
  3. HP Chromebook 14-x010wm Motherboard Replacement: 3 단계, 이미지 1/1
    • Lift the keyboard tray carefully and disconnect the ribbon cables before setting it aside.
  4. HP Chromebook 14-x010wm Motherboard Replacement: 4 단계, 이미지 1/2 HP Chromebook 14-x010wm Motherboard Replacement: 4 단계, 이미지 2/2
    • The motherboard is located in the top left corner of the laptop.
    • Be sure to disconnect the battery as well as any other connectors on the motherboard.
    • We recommend a prying motion on the two power cords seen in the top right of the motherboard.
  5. HP Chromebook 14-x010wm Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove all the screws securing the motherboard down.
  6. HP Chromebook 14-x010wm Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the copper heat sink and then remove the motherboard using a tilting motion for the ports to slip out of the plastic casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 03/30/22
190 평판
안내서 1개 작성함
IUPUI, Team 1-1, Harley Spring 2022 IUPUI, Team 1-1, Harley Spring 2022 회원
IUPUI-HARLEY-S22S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 18
전체 시간: 207
