소개
This guide will walk you through all the steps to remove the motherboard from your HP Chromebook 14-x010wm. You may find it reasonable to replace your motherboard if your CPU and/or I/O ports are damaged. This is a bit more challenging of a replacement process.
Be sure to take your time and not rush any steps.
필요한 것
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
