주요 콘텐츠로 건너뛰기
HP Chromebook 14-x010wm Speaker Replacement
필요한 것
  1. HP Chromebook 14-x010wm Speaker Replacement, Speaker: 1 단계, 이미지 1/2 HP Chromebook 14-x010wm Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Begin by flipping the laptop over to its backside.
    • Remove all 13 Phillips #00 screws (5.7 mm in length).
    • You must remove four rubber feet to remove the top corner screws.
  2. HP Chromebook 14-x010wm Speaker Replacement: 2 단계, 이미지 1/1
    • Turn the laptop over and open it to face you.
    • Insert a prying tool between the keyboard and bottom cover, and slide the prying tool in a counter-clockwise direction to separate the casing.
  3. HP Chromebook 14-x010wm Speaker Replacement: 3 단계, 이미지 1/1
    • Once detached, carefully lift the keyboard upwards.
    • Disconnect the two ribbon cables attached to the motherboard.
  4. HP Chromebook 14-x010wm Speaker Replacement: 4 단계, 이미지 1/3 HP Chromebook 14-x010wm Speaker Replacement: 4 단계, 이미지 2/3 HP Chromebook 14-x010wm Speaker Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift the black ZIF tab and disconnect the daughterboard ribbon cable.
    • Use a nylon spudger or tweezers to disconnect the cable connecting the battery and the motherboard by sliding it out in the downward direction.
    • Disconnect the speaker cable from the motherboard.
  5. HP Chromebook 14-x010wm Speaker Replacement: 5 단계, 이미지 1/2 HP Chromebook 14-x010wm Speaker Replacement: 5 단계, 이미지 2/2
    • Once all connections have been removed, begin unscrewing all nine screws from the battery.
    • Lift the battery carefully and put aside.
  6. HP Chromebook 14-x010wm Speaker Replacement: 6 단계, 이미지 1/3 HP Chromebook 14-x010wm Speaker Replacement: 6 단계, 이미지 2/3 HP Chromebook 14-x010wm Speaker Replacement: 6 단계, 이미지 3/3
    • Lift the adhesive tape.
    • Once the tape has been lifted, both left and right speakers can be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Karine Veruete
회원 가입일: 03/30/22
163 평판
안내서 1개 작성함
IUPUI, Team 1-1, Harley Spring 2022 IUPUI, Team 1-1, Harley Spring 2022 회원
IUPUI-HARLEY-S22S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 11
전체 시간: 64
