주요 콘텐츠로 건너뛰기
HP Chromebook 14-x010wm Touchpad Replacement
필요한 것
  1. HP Chromebook 14-x010wm Touchpad Replacement, Touchpad: 1 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement, Touchpad: 1 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement, Touchpad: 1 단계, 이미지 3/3
    • Before starting the fix, make sure the computer is turned off, the power is disconnected, and all external devices are disconnected as well.
    • Close the laptop lid.
    • Turn the laptop upside-down.
  2. HP Chromebook 14-x010wm Touchpad Replacement: 2 단계, 이미지 1/2 HP Chromebook 14-x010wm Touchpad Replacement: 2 단계, 이미지 2/2
    • Remove the two larger rubber screw covers.
    • Remove the two smaller rubber screw covers.
    • Remove the middle rubber screw cover.
  3. HP Chromebook 14-x010wm Touchpad Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the thirteen 5.7 mm screws located on the back of the device as shown.
  4. HP Chromebook 14-x010wm Touchpad Replacement: 4 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement: 4 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement: 4 단계, 이미지 3/3
    • Turn the computer right side up with the front facing towards you.
  5. HP Chromebook 14-x010wm Touchpad Replacement: 5 단계, 이미지 1/2 HP Chromebook 14-x010wm Touchpad Replacement: 5 단계, 이미지 2/2
    • Carefully open the computer’s lid as far as it will go until the back edge of the keyboard cover separates from the base.
    • Opening the lid too far may cause damage to some of the internal pieces of the laptop.
  6. HP Chromebook 14-x010wm Touchpad Replacement: 6 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement: 6 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement: 6 단계, 이미지 3/3
    • Using a plastic opening tool, pry open along the front edge and the sides of the keyboard cover to separate it from the computer’s base.
    • Carefully lift the keyboard cover from the computer’s base.
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
  7. HP Chromebook 14-x010wm Touchpad Replacement: 7 단계, 이미지 1/2 HP Chromebook 14-x010wm Touchpad Replacement: 7 단계, 이미지 2/2
    • Using a spudger, remove the battery cable by slowly pulling the plastic connector towards you.
  8. HP Chromebook 14-x010wm Touchpad Replacement: 8 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement: 8 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement: 8 단계, 이미지 3/3
    • Using a spudger, lift the black plastic flap of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by pulling it from the system board.
  9. HP Chromebook 14-x010wm Touchpad Replacement: 9 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement: 9 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement: 9 단계, 이미지 3/3
    • Using a spudger, lift the black plastic flap of the zero insertion force (ZIF) connector that holds the TouchPad cable in place.
    • Disconnect the TouchPad cable by pulling it from the system board.
    • At this point, the keyboard cover should be completely detached from the computer’s base.
  10. HP Chromebook 14-x010wm Touchpad Replacement: 10 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement: 10 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement: 10 단계, 이미지 3/3
    • Remove the keyboard cover by sliding it towards you.
    • Turn the keyboard cover upside down.
  11. HP Chromebook 14-x010wm Touchpad Replacement: 11 단계, 이미지 1/3 HP Chromebook 14-x010wm Touchpad Replacement: 11 단계, 이미지 2/3 HP Chromebook 14-x010wm Touchpad Replacement: 11 단계, 이미지 3/3
    • Using a spudger, lift the black plastic flap to release the TouchPad cable from the connector.
    • Disconnect the TouchPad cable by pulling it away from the connector.
  12. HP Chromebook 14-x010wm Touchpad Replacement: 12 단계, 이미지 1/2 HP Chromebook 14-x010wm Touchpad Replacement: 12 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the two 2.4 mm screws that secure the TouchPad to the keyboard cover.
  13. HP Chromebook 14-x010wm Touchpad Replacement: 13 단계, 이미지 1/2 HP Chromebook 14-x010wm Touchpad Replacement: 13 단계, 이미지 2/2
    • Lift the keyboard cover. The TouchPad will be detached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thiago Leal Figueira
회원 가입일: 02/15/17
113 평판
안내서 1개 작성함
USF Tampa, Team 15-2, Remmell Spring 2017 USF Tampa, Team 15-2, Remmell Spring 2017 회원
USFT-REMMELL-S17S15G2
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 1,990
