소개
This guide walks through how to remove a malfunctioning camera in an HP Chromebook 14-x013dx. This replacement requires disabling the keyboard from the laptop and removing the lid, and the total repair time should take about 30 minutes.
필요한 것
Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
Disconnect the black and white wires connected to the Wi-Fi module.
Remove the wire from the casing.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you, very helpful. You could also just start at Step 10 without removing the display
