주요 콘텐츠로 건너뛰기
HP Chromebook 14-x013dx I/O Board Replacement
필요한 것
  1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: 1 단계, 이미지 1/2 HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: 1 단계, 이미지 2/2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx I/O Board Replacement: 2 단계, 이미지 1/1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx I/O Board Replacement: 3 단계, 이미지 1/2 HP Chromebook 14-x013dx I/O Board Replacement: 3 단계, 이미지 2/2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx I/O Board Replacement: 4 단계, 이미지 1/2 HP Chromebook 14-x013dx I/O Board Replacement: 4 단계, 이미지 2/2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx I/O Board Replacement: 5 단계, 이미지 1/3 HP Chromebook 14-x013dx I/O Board Replacement: 5 단계, 이미지 2/3 HP Chromebook 14-x013dx I/O Board Replacement: 5 단계, 이미지 3/3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: 6 단계, 이미지 1/2 HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: 6 단계, 이미지 2/2
    • Unhook the ribbon connecting the I/O board and the battery.
    • To remove the ribbon, lift the latch holding the ribbons in place and then pull them free.
  7. HP Chromebook 14-x013dx I/O Board Replacement: 7 단계, 이미지 1/2 HP Chromebook 14-x013dx I/O Board Replacement: 7 단계, 이미지 2/2
    • Remove two 2mm screws from the I/O board using the Phillips PH00 screwdriver.
  8. HP Chromebook 14-x013dx I/O Board Replacement: 8 단계, 이미지 1/1
    • Lift the I/O board out of the laptop case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
NHerbert
회원 가입일: 09/28/17
602 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 회원
USFT-NANCE-F17S3G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 450
