이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
Remove the two 2mm screws holding the bezel to the laptop case.
Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
Once glue is separated, pop out the front cover by pulling upwards on the hinge.
Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
Before completely removing the screen, detach the connected located at the bottom of the screen.
다른 3명이 해당 안내서를 완성하였습니다.
