주요 콘텐츠로 건너뛰기
HP Chromebook 14-x015wm Battery Replacement
필요한 것
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Chromebook 14-x015wm Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: 2 단계, 이미지 1/1
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: 3 단계, 이미지 1/2 HP Chromebook 14-x015wm Battery Replacement: 3 단계, 이미지 2/2
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
결론
Cameron Sinclaire
회원 가입일: 10/27/17
201 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 1,363
