주요 콘텐츠로 건너뛰기
HP Chromebook 15 CB3-531-C4A5 Battery Replacement
필요한 것
  1. HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: 1 단계, 이미지 1/2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: 1 단계, 이미지 2/2
    • Remove the 18 Phillips screws using a screwdriver with a PH0 bit.
  2. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 2 단계, 이미지 1/2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 2 단계, 이미지 2/2
    • Using a spudger, gently pry open the back from the top.
  3. HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Once it is opened up, locate the battery and the cable that is attached to it.
  4. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 4 단계, 이미지 1/2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 4 단계, 이미지 2/2
    • Next, unscrew the battery pack. The one screw should be located on the far right of it. This will ensure that the battery comes out easily and affectively.
  5. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 5 단계, 이미지 1/1
    • Take the battery out easily for replacement.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Savannah Vining
회원 가입일: 01/17/17
922 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 10
전체 시간: 2,083
