주요 콘텐츠로 건너뛰기
HP Chromebook CB2L Keyboard Replacement
필요한 것
  1. HP Chromebook CB2L Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. HP Chromebook CB2L Keyboard Replacement: 2 단계, 이미지 1/2 HP Chromebook CB2L Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
  3. HP Chromebook CB2L Keyboard Replacement: 3 단계, 이미지 1/3 HP Chromebook CB2L Keyboard Replacement: 3 단계, 이미지 2/3 HP Chromebook CB2L Keyboard Replacement: 3 단계, 이미지 3/3
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  4. HP Chromebook CB2L Keyboard Replacement: 4 단계, 이미지 1/2 HP Chromebook CB2L Keyboard Replacement: 4 단계, 이미지 2/2
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Keyboard Replacement: 5 단계, 이미지 1/2 HP Chromebook CB2L Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
  6. HP Chromebook CB2L Keyboard Replacement: 6 단계, 이미지 1/3 HP Chromebook CB2L Keyboard Replacement: 6 단계, 이미지 2/3 HP Chromebook CB2L Keyboard Replacement: 6 단계, 이미지 3/3
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
  7. HP Chromebook CB2L Keyboard Replacement: 7 단계, 이미지 1/2 HP Chromebook CB2L Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove the speakers and battery.
  8. HP Chromebook CB2L Keyboard Replacement: 8 단계, 이미지 1/2 HP Chromebook CB2L Keyboard Replacement: 8 단계, 이미지 2/2
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
결론
Nathan Petrie
회원 가입일: 10/31/18
277 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G4, Harley Fall 2018 IUPUI, Team S1-G4, Harley Fall 2018 회원
IUPUI-HARLEY-F18S1G4
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 176
