주요 콘텐츠로 건너뛰기
HP Chromebook x360 14-da0011dx Battery Replacement
필요한 것
  1. HP Chromebook x360 14-da0011dx Battery Replacement, Lower Case: 1 단계, 이미지 1/1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Battery Replacement: 2 단계, 이미지 1/2 HP Chromebook x360 14-da0011dx Battery Replacement: 2 단계, 이미지 2/2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Battery Replacement: 3 단계, 이미지 1/3 HP Chromebook x360 14-da0011dx Battery Replacement: 3 단계, 이미지 2/3 HP Chromebook x360 14-da0011dx Battery Replacement: 3 단계, 이미지 3/3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. HP Chromebook x360 14-da0011dx Battery Replacement, Battery: 4 단계, 이미지 1/2 HP Chromebook x360 14-da0011dx Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the cable attached to the battery.
  5. HP Chromebook x360 14-da0011dx Battery Replacement: 5 단계, 이미지 1/2 HP Chromebook x360 14-da0011dx Battery Replacement: 5 단계, 이미지 2/2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. HP Chromebook x360 14-da0011dx Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the chassis.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jared Tallent
회원 가입일: 02/14/23
196 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 36
전체 시간: 637
