소개
If the bottom cover of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom cover. For this guide, you will need the Phillips #1 screwdriver and a plastic spudger.
필요한 것
Position the device upside-down on a flat, level surface with the USB ports facing you.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
