주요 콘텐츠로 건너뛰기
HP Chromebox J5N50UT Bottom Cover Replacement
필요한 것
  1. HP Chromebox J5N50UT Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT Bottom Cover Replacement: 2 단계, 이미지 1/1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Bottom Cover Replacement: 3 단계, 이미지 1/1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Bottom Cover Replacement: 4 단계, 이미지 1/1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashley Marvin
회원 가입일: 09/06/18
685 평판
안내서 5개 작성하였습니다
Ohio State, Team S1-G3, Whitney Fall 2018 Ohio State, Team S1-G3, Whitney Fall 2018 회원
OSU-WHITNEY-F18S1G3
2 회원들
안내서 5개 작성하였습니다
댓글 한 개
Can you explain how/where the integrated VESA mount is?
Is the mounting screw holes under the rubber feet, like other chromeboxes, from other makers?
When Ze - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 570
