소개
If the hard drive of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the hard drive. For this guide, you will need the Phillips #1 screwdriver.
필요한 것
Position the device upside-down on a flat, level surface with the USB ports facing you.
Lift the two pieces of mylar tape from the bracket.
Flag: Confusing Text
in steps 5 and 6 it seems the bottom shield is called a bracket, so by using 2 different names it’s making it seem like we’re missing a piece/part
Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
another picture of where to insert the spudger may be helpful. which ports are you talking about?
Flag: Needs More Images
Flag: Missing Details
a note step on paying attention to how the shield is positioned before removing it may make reassembly easier
Disconnect the white and black antenna cables from the module.
Flag: Markup Mishap
iFixit has in their Milestone 3 instructions to not use arrows. we recommend either a box over each connector or a rectangular box over the 2 instead
Using your Phillips #1 screwdriver, remove the M2.0×3.0 screw from the upper left corner of the module.
Flag: Needs Better Images
we don’t think picture 2 is needed at all.
picture 3 doesn’t really show how the module has popped up. the angle is wrong to make it obvious
Remove the Phillips M2.0×3.0 screw.
more information about which screw and where it’s located could be helpful. if you don’t look at the pictures there’s no way to tell which screw is indicated or which component is the hard drive
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
actually you can flip open metal bracket with just one mylar tape
and there is 5 screws, not 4. if you look, you will see triangle arrow stamped on bracket indicating which screws to remove.
you can swap the ssd without removing the wifi board
do this all the time, saves a lot of steps
both for the cover replacement and shield replacement
Ian Stoffel - 답글
For the hard drive replacement, a longer times should be indicated. for the WLAN replacement 15 minutes is indicated, but for the hard drive replacement, which can only be done after the WLAN replacement, the time is listed as 10 minutes.
Ian Stoffel - 답글
