주요 콘텐츠로 건너뛰기
HP Color LaserJet Pro MFP M277dw Display Replacement
필요한 것
  1. HP Color LaserJet Pro MFP M277dw Display Replacement, Display: 1 단계, 이미지 1/1
    • Lift up the top of the printer by pulling up on it.
  2. HP Color LaserJet Pro MFP M277dw Display Replacement: 2 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Display Replacement: 2 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Display Replacement: 2 단계, 이미지 3/3
    • Remove one Phillips #2 15mm screw.
    • Use the plastic opening tool to remove the top of the display component.
    • The cable connecting the display to the motherboard should be visible.
  3. HP Color LaserJet Pro MFP M277dw Display Replacement: 3 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Display Replacement: 3 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Display Replacement: 3 단계, 이미지 3/3
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove the left side panel.
    • Flipping the printer onto its side makes it easier to remove the panel and access the motherboard.
  4. HP Color LaserJet Pro MFP M277dw Display Replacement: 4 단계, 이미지 1/1
    • Unplug the display from pink cable from the circuit board.
    • Connecting a new display will require you to feed the cable through the printer.
    This step could have used some further elaboration. As someone posted below, you can do it if you don’t try to follow the original path.
    David Weld - 답글
결론
다른 5명이 해당 안내서를 완성하였습니다.
Christopher Fahey
회원 가입일: 10/08/18
744 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 회원
CPSU-WHITE-F18S4G2
3 회원들
안내서 10개 작성하였습니다
댓글 8개
where do you get a new screen
Seizure Salad - 답글
Would like to know too where to get a new screen
Bernd Kohnen - 답글
“Connecting a new display will require you to feed the cable through the printer”
Well, it’s actually not too complicated, you don’t need to take any additional parts to do it. Just take out the display (also need to unscrew two black screws inside, first and then grounding cable) and pull the cable out (do it a bit harder as it’s tight), and then when you change the display, feed the cable through by using different path.
In terms of finding the display, it’s not easy, as hp doesn’t sell it. You are may be lucky to find it on eBay…
az2181 - 답글
looked on ebay could not find maybe you have another place
mariamaxwell88 - 답글
where we can get the new display could you advise.
Mahmoud Mizo - 답글
Found a replacement touchscreen on eBay (“HP Printer Pros” in Texas) for $35.
David Weld - 답글
Replacement touchscreen is available on iteminc.com
mag pie - 답글
thank you so much, this was really helpful
ymasea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 23
30일 전: 127
전체 시간: 9,573
