주요 콘텐츠로 건너뛰기
HP Color LaserJet Pro MFP M277dw Power Button Replacement
필요한 것
  1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: 1 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: 1 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: 1 단계, 이미지 3/3
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove right side panel by prying it off.
    • Flipping the printer onto its side makes it easier to remove the side panel.
  2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: 2 단계, 이미지 1/2 HP Color LaserJet Pro MFP M277dw Power Button Replacement: 2 단계, 이미지 2/2
    • Lower the front panel by pulling it down from the upright position.
    • The button cover should come off with the panel, if it does not be sure to remove it.
  3. HP Color LaserJet Pro MFP M277dw Power Button Replacement: 3 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: 3 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: 3 단계, 이미지 3/3
    • Remove two Phillips #2 8mm screws.
    • Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Fahey
회원 가입일: 10/08/18
774 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 회원
CPSU-WHITE-F18S4G2
3 회원들
안내서 10개 작성하였습니다
댓글 2개
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
Ajay Kumar Singh - 답글
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
Sheila Shook - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 35
전체 시간: 2,704
