주요 콘텐츠로 건너뛰기
HP Color LaserJet Pro MFP M277dw Power Module Replacement
필요한 것
  1. HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: 1 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: 1 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: 1 단계, 이미지 3/3
    • Open and lower the back panel by pulling it down.
    • Remove one Phillips #2 10 mm screw.
  2. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 2 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 2 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to remove the right side panel of the printer.
    • Flipping the printer on its side, with the right side facing up, will make it easier to remove.
  3. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 3 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 3 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 3 단계, 이미지 3/3
    • Remove two Phillips #2 12mm screws.
    • Remove four different pin connectors that attach to the power module located at the bottom.
    • Removing the white connector is made easier with assistance of a spudger/flat tip that loosens the clamp.
  4. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 4 단계, 이미지 1/2 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 4 단계, 이미지 2/2
    • Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
  5. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 5 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 5 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 5 단계, 이미지 3/3
    • Slowly lift the power module from the printer using both hands.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Lyndon Fresnido
회원 가입일: 10/08/18
184 평판
안내서 1개 작성함
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 회원
CPSU-WHITE-F18S4G2
3 회원들
안내서 10개 작성하였습니다
댓글 2개
Hello, wäre can i buy the power supply? Thank you
Jakob Hetzendorfer - 답글
Thanks a lot - also works for model M281fdw
patrik maurer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 61
전체 시간: 4,288
