소개
If your printer is improperly taking in your paper through the bottom tray, you may need to replace your rollers. With nothing but a #2 Phillips screwdriver, you will be able to quickly remove them.
필요한 것
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you!
Should the black roller just behind these two rollers also be replaced?
Best wishes
Mark
