주요 콘텐츠로 건너뛰기
HP Color LaserJet Pro MFP M277dw Wireless Card Replacement
필요한 것
  1. HP Color LaserJet Pro MFP M277dw Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/1
    • Remove paper tray by pulling it straight out.
    • The tray should just slide out with little to no resistance.
  2. HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 2 단계, 이미지 1/3 HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 2 단계, 이미지 2/3 HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 2 단계, 이미지 3/3
    • Lower the back panel by pulling it down from the upright position.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove the left side panel.
    • Flipping the printer onto its side makes it easier to remove the panel and access the motherboard.
  3. HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 3 단계, 이미지 1/2 HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 3 단계, 이미지 2/2
    • Remove one Phillips #2 11mm screw.
    • Remove the wireless card.
    • The wireless card is connected to the circuit board with pins, it will take a bit of force to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Fahey
회원 가입일: 10/08/18
744 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 회원
CPSU-WHITE-F18S4G2
3 회원들
안내서 10개 작성하였습니다
댓글 3개
Would you share the part number of the module, better off a link to where it is sold. Thanks.
Jonathan Chan - 답글
can this wireless card be upgraded to say a more modern one where it accepts wap3?
BenGie Cruz - 답글
I’m just curious if you’ve ever left off the WiFi card and powered it up. Does the printer take away the entry for wifi settings on the display if you do this?
Jonathan Wolff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 46
전체 시간: 3,874
